seahorseshoes
2hp Johnson Seahorse 1982
I bought a motor that I knew wasn't running great. From it's condition it looks like I'm not the first person who's attempted to get this thing to run right. Everything seems clean and in good condition.
Motor runs badly and at only one setting. Won't idle, won't run fast.
Only runs when throttle set a bit faster than the start position.
Ignition
Looked in very good condition. Set at .020.
New spark plug, gapped.
Reed Valves
Good condition. Fully closed and open just fine.
Fuel
Gas tank clean. New fuel. Clean see-thru inline filter.
Carb
Spotless. I even pulled out the expansion plug.
All tiny passages are clean and open.
Cylinder
Didn't visually inspect but compression is 90psi
Carb adjust
I did the one full turn out and 1 1/2 turns out.
Made sure (gently) to ensure the screws were fully seated before turning open.
Needle/screws looked to be in good condition.
Fine tuning of carb
I know the instructions for tuning say: (High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve.
I attempted this but it doesn't seem to help. Everything seems to result in stalling.
I'm stumped. Advice appreciated.
Ignition
Reed Valves
Fuel
Carb
Cylinder
Carb adjust
Fine tuning of carb
