welshswampy
Hi all, just a couple of questions
I'm probably going to buy a 170 hp GM v8 6.2 diesel which doesn't come with an outdrive, but with a VP bell housing
I've found an early VP 290 duoprop with a 1.78/1 gear ratio that was reconditioned around 8/10 yrs ago
1, would the drive ratio by OK for the engine I plan to buy
2, if the seals etc were replaced that long ago without being used wouldn't they now need replacing again(seller says that drive was reconditioned, filled with oil then never used)
3, is it much of a job to replace seals etc on this drive
4, if this drive has sat unused for 8/10 yrs, is there likely to be any other problems, internal corrosion issues maybe(water neck fitting was renewed)
Sorry I dont have the exact model of the drive, but thats all the info I have at the moment
Regards Nick
PS dont now if I'm in the right forum
Regards Nick
