That can and will help, but the important area that is prone to breaching a good seal, is where the aft-most O-ring is to fully contact the full circumferance of the inner bore inside of the clamping collar.I see it all the time also Rick. As you do, just throw some "aviation sealer" on it and stick it together. I don't think there's that much of a chance to hurt anything. I'll bet I have seen more like these than ones in 1oo% shape.
Gary and Rick,
Thanks again for all of the info. ...................
#1 will have to replace only two of the small bearings on the verticle shaft in the lower (and the needles on the upper,,,cheap insurance)
#2 I will have to replace almost all of the bearings, but will use the best components af all three drives, so it will be almost new, bearing wise
#3 will do at a later date, as it has some issues such as a stuck needle bearing cage in the lower. All are being prepped for paint now, I start with removing the corrosion to bare metal, spotting those areas with a zinc primer, then any filling and sanding Hit it with an epoxy primer over the entire drive, and then finally the topcoat, a honda grey I have leftover from a previous paintjob.
Still getting all the machined surfaces flat and true, then need to sand in stages before priming.
Gary, I finally got that gear off the propeller shaft today. Bent my press, so I had to "coax" it out with a sledge and a pipe...broke my sledge handle in the process. The other two gears pressed off as easy as you please on the other propeller shafts.
Thanks again guys.
Aloha
