am_dew
Advanced Contributor
Yesterday, while on plane in my 17' v-hull runabout while cruising through some areas that had clumps of floating grass in it, suddenly it sounded like my prop slipped. I immediately backed off the throttle and turned the engine off, the raised the outdrive to check and see if any grass had wrapped in the prop. There was some but not alot and I cleared what was there. I lowered the drive, started the engine and cautiously increased throttle to get on plane. It then was fine for the rest of the 15 mile or so trip back to the launch ramp. The prop had not spun on the hub nor had it spun on the shaft...it's the kind of prop secure where you have the tabbed washer...not centter bolt. Does the 270 have some sort of internal protection that would have caused this "slippage" (for lack of a better term)?
