fredbriggs
Been having on going problem with this engine. Was a no start had weak spart, and pushing a lot of fuel out #1 cyl, figured that out now have good spark too both plugs, rebuilt carb, new leaf valves, new fuel pump, good compression (135) both cylinders. Now still no start and and while cranking over back fires out exhaust only. Flywheel key ok, thinking something to do with timing? Brought #1 cyl up to top dead center with dial indicator in number 1 and marks on flywheel right on. Only problem I could see now is that the tiller handle linkage is slightly worn and when returned to idle position does not bring the marks on flywheel exactly to the throttle linkage roller but not off enough that it shouldnt start. Even if I manually put mark on roller still back fires? Plugs are getting wet with fuel but engine wont run? I did have the advance plate and stator off to check stator and all coils and trigger all checked good with ohm meter all within factory specs. Any suggestions would be appreciated
