jumping jack
Will not idle unless choke is out. Runs super at high speed, have given two dose of carb cleaner OMC type. All fuel lines and filters checked and rechecked. Suggestions appreciated. Jack
Thanks for reply, knew that, but trying to avoid if there was something I overlooked.Take the carb apart and clean it correctly. And buy a good quality carb kit with the fuel pump and primer assemblies.
Do what you want. I can't make you fix it correctly it's your motor!Thanks for reply, knew that, but trying to avoid if there was something I overlooked.
JJ
