"I've got a 1977 AQ255A wi
"I've got a 1977 AQ255A with 280 outdrive. My impeller disinigrated. I've cleaned out pieces from the engine (what a pain), replaced the heads (cracked) and replaced the impeller. It worked fine for a while, then failed again. The impellor looks fine, but won't pump at all. I'm wondering if I got the wrong impeller. Couldn't find any identification on the pump, so I ordered by measurement. The shaft size seemed right, and the impeller was a tight fit. Can anyone tell me which part number I should be using? Here's a drawing of the pump. I can take actual pics if needed.
