cannonballkev
"Newest problem on boat that h
"Newest problem on boat that has been fine until this year. Boat worked great sat and half of sunday then all of a sudden it would die at 4000 RPMS, and I had trouble starting it back up, did this several times.
Acted like a fuel restriction problem, took out and cleaned in line fuel filter, wasnt dirty to the eye.
Old gas was in boat but have added 20 gal of new gas last two days.
have not changed fuel gas seperator in a while
plugs look decent, #1 qas a little black, but dry
I think my altenator is out (if I turn perko switch to off motor dies, is it supposed to die.
I thought motor would run off of altenator.
If ALT is dead could this be my problem, bat is to low to supply enough voltage at higher RPMS?
Also, I have put 3 solenoids on this thing, starter keeps staying engaged (new starter also)
I can wack the solonied and it will start working.
ANY suggestions?
On a positive note< the used 2.3 outdrive is working like a charm, adjusted shift cable and it shifts like butter(without the ESA working!)
Kev"
ANY suggestions?
Kev"
