Shifter is in neutral and kill switch is on, turn the key and nothing. The battery is charged. Took it out Friday and started every time but had problems with it wanting to go in gear. We put it in forward and had to give it some gas from the hot foot before it went into gear. If you put it in reverse you would have to take and push it up into forward to get it out of reverse. So is there a swicth inside the shifter that tells the motor that its in neutral? could this be bad if so?
