20hp Johnson ID from late 60s to early 70s
mack
" Hello,
I'm tring to
" Hello,
I'm tring to find out what my year and model #s are. The plate on mounting bracket is gone and I have look all over engine for a welch plug with no luck. I have found a lot of part #s. Block #384602, carb. mounting plate #3846696, flywheel #315840 M, coil mounting plate #580360 D 1-1 G, cam lope #316583, points condensers #580321.
The motor is a 20hp Johnson from late 60s to early 70s.
Thanks for any help! You have a great web site!
Mack "
"Mack.... With no model number
"Mack.... With no model number to use, that's a toughy. Those other numbers could pertain to many models. Various pictures of the engine might help if you could get them to us.
Joe
