" The problem that I'm hav
" The problem that I'm have is with a 20hp Johnson. It starts with one pull,idles good in neutral and in gear,has high rpms in neatral but, when rived in gear ether bogs or dies. Sometime when it bogs after a while it may go ahead and run normally. I've rebuilt carb, changed plugs,changed oil in lower unit,but, no help. I've notice some oil leaking from exhaust port into water, could lower unit be bogging engine or should I look else where. This is a points ignition.
Thanks for the help.
Mack "
Mack "
