Can you decode this please?2017 f115 208hours. I'm getting a tps code and when I use yds and check it out. The value that's supposed to be between 0-90 is 7992.2 anyone got some insight on this? Even if I unplug the tps sensor it doesn't change.
Service Manual calls for the TPS check to output voltage. One volt with the throttle closed.
Your screen shot is showing degrees.
