Robinhood493
2014 115 4 stroke Serial # 2B078051. Engine has a no start. When the key is turned, everything turns on, but the engine doesn't try to turn over. I checked continuity from the key switch all the way to the starter on the yellow with red stripe wire. It seems as though the wire would be broken between the 14 pin cannon plug and the white plastic square plug under the console. This would be the last thing that I would have thought would break due to how the harness is made. It seems like this boat has a neutral switch on the controls and another on the engine. They both have continuity when in neutral, and no continuity when in gear. It also has 2 starter solenoids/relays. Also the wire seems tight in both ends of the wiring plugs. I tried looking for a wiring diagram but can't find one. Anything else I may have missed?
