2007 mercury 6hp dies in gear
jessedubreuil
Hey guys have a 2007 6hp mercury 4 stroke and it will run all day in neutral but when you put it in gear it runs for about 15 seconds the dies and puffs out the carb a little bit, it’s got good gas new fuel filter and fuel pump, I’ve had the carb apart 3 times and on the third time I had it in a ultra sonic cleaner for 3 hours with no change, had good compression as well. What are your thoughts? Should I buy a new carb or is there something else that is common on these? Thanks
serial number is 0R196407
