Hello,
My 2006 verado 150 fills #4 cylinder with fuel, injectors cleaned this week. No issues remove plugs and fuel qpours out of cylinder #4 even with injector rail removed from intake. Crank engine over and sprays it out. Turn by hand and use flash light you can see the fuel raise in the plug hole then as you turn over by hand pushes all fuel out after couple turns. Turn key on an fuel pump fills all lines same thin occurred with out injectors even in the intake???
