Can anyone tell me how to do a
Can anyone tell me how to do a static check on the T8 charging system. Not sure the problem is with the alternator or power pack (rectifier). Would like to make sure I order the correct part. The problem is that when the voltage is monitored across the battery while the motor is running the voltage jumps around (does not steadly increase as you monitor it over time)Not problem with battery since the main motor will charge the battery properly.
