2006 Merc 350 mag dies after a couple of minutes.
skinut1
I have a 2006 Crownline 240EX with a 350 mag and bravo III outdrive. It starts easy and it will run like a sewing machine for a few minutes and then just dies like you turned the key off. If I push in the little button on the throttle and put it in neutral and give it some gas it will start and run forever as long as I keep the rpms above 1000. But, when I pull it back to idle it dies. Any ideas as to the problem. I was thinking maybe a choke issue since it happens after it warms up to about 140 after a couple of minutes running? It has about 200 hours on it since new.
Thanks for the help.!!
