darlington_john
I have a 2006 Yami F150hp with less than 90 hrs run time and it seems to go through batteries every other month. I just purchased this boat used in the spring and realized that the factory hookup on this was to have all of the accessories and power cables from the outboard run to a single starting battery. I have changed this out with a battery with 1000 cranking amps which is better than what is stated in the manual. Problem is, and always has been, that the engine sounds like the battery is dead even though that it is a new battery as it turns over slowly but fires up. This is usually good only for about 5 - 6 trips and then the battery cannot turn the engine over. I only run a fishfinder and do not put any other accessories on - including the radio. A quick look online shows that even a single F150 should be run with 2 batteries; one for cranking and one for accessories which makes perfect sense and that is what I'm doing. BUT, it states that you have to remove the accessory battery coupler cover from the outboard motor to run this to the accessory battery. Where is this on the engine as I've looked and I couldn't locate anything. Is this an accessory that I have to purchase and if so, is this an easy install or should I take it to a stealership, oops, I mean dealer?
