A few weeks ago I had a hard time starting my boat, it would crank and finally I was able to start it after multiple times with the key turned. I was afraid I would burn out the starter. Well, this past week I turned my key and nada. Just a little humming somewhere on the engine, possibly a relay? I pulled starter off, pulled it apart, cleaned up and put back together as well as replacing starter solenoid. It bench tests fine. I installed starter and it still hums when I turn the ignition key. If I jump the starter from the coil to starter, it will start. My battery cable are good and tight, no corrosion. I'm wondering where the fuse or relays (if any) are that control this. Or gimme some ideas please. Thanks in advance
