Problem
I have a 2005 carb'ed merc 75HP outboard came with a boat I bought last year.
Did have a slight stumble would run fine for 30 sec or more.. then sputter ONCE.. then fine.. for 30+ seconds.
All of a sudden... it died one day would not start
Checked stator .. fine. (bought the special tool to do it..with your multimeter)
I rebuilt carbs.. insane white powder in carbs from previous owner.. installed 4 carb kits..
Engine fired right up
Still has that occasional stumble..gets better when warm.. does not go away. No change from before.
Like a slight cough every 30-60 sec.. varies.
HAVE NOT changed fuel pump.. but it did "pump" when disconnected the hose. (Maybe a pinhole in diaphram?.. No rebuild kits avail .. ordered new pump)
INTERESTING..
When I put hand over intake runners (induction silencer) engine speeds right up
?? Running rich??
I did replace all o-rings in all the carb plates .. 100%
Its an EPA version of carbs.. so the pilot screw is capped.. and not adjustable (?remove cap.. clean? Adjust? or replace?)
(all else cleaned.. )
Would this problem typically be fuel pump.. or should I remove the seal on the pilot jets.. and replace them/clean them?
Why would it speed up when I hold 1/2 a hand over the intake runners? (not anywhere near blocking them off)
I have not yet synced the carbs.. (have the gages.. no done yet.. would this cause such a problem?)
Rings / Valves carboned up?
Could it be a head gasket leak.. but ...No fluid in oil... at all .. clean as a whistle... no oil in the water either..
?? Exhaust leak??
Suggestions Please?
Outboard SN 1E000385
Thanks in advance, and sorry for such a large post.
Andrew
- Checked all electrical/spark/coils/computer/ fine as per service manual
- Changed fuel filter
- Rebuilt lower end (just because)
- Changed all fluids/filter
- Changed all fuel lines
- Changed all fuel
- Compression fine.
- No backfiles.. happens with cowling on or off
- Replaced all filters INSIDE the carbs..
- Check valve on carbs appeared ok.. (will double check #804198)
- Replaced all plug wires.
- Have good output from coils.
- Replaced Throttle Sensor.. was bad.. potentiometer had NO reading.. new one is in spec as per manual.
- Replaced Voltage Reg. (old one that came with boat was blown to bits.. big hole in it.. new one works fine and charges fine..prev. owner lied about engine)
INTERESTING..
?? Running rich??
?? Exhaust leak??
Suggestions Please?
Andrew
