2004 Yamaha 50 ELRC
mill686
Looking at a 2004 50ETLRC outboard. Was wondering if someone could tell me the correct part numbers for a binnacle control and multifunction tach that are compatible with this model year?
Thanks.
Greg
By binnacle control I presume you mean a top mounted control box. Model is 704. Standard and Premium models are available. In addition to the control box you will need the ten pin main engine harness, a key switch and control cables.
The tachometer is a 6Y5-8350T-XX-00. You will need some harnesses to make it work.
Most all of the rigging stuff can be seen in here. https://yamahaoutboards.com/catalog/2018/MRP/index.html#page=1
