Randy Brunson
Hello
After being out of the water for a few weeks, I went to put the boat in and when I tilted the motor up, I noticed it was having a hard time. After doing a few other things, I tried it again, and this time it couldn't lift the motor. I went back to inspect and noticed a leak around the port side trim cylinder. The trim motor sounds fine...
Anybody have something similar to this happen?
Is there any chance I can replace Part #46 on the Boats.net Power Trim & Tilt Diagram which includes the rod guide and some seals and get away with it? Or is this more likely a major repair?
https://www.boats.net/catalog/honda...-baej-1200001-to-baej-1299999/power-trim-tilt
Also, there's two part numbers listed for #46, though they both reference the same Serial Number range. Any idea which one is right?
As always, thanks for the advice!
