littledutch
I have a 2004 250hp Evinrude 2stroke, saltwater edition. Has over 600 hours on it. Was running about 4700-4800 RPM's with a full tank of gas, dive gear, four people, seas 2-3 occasional 4 footer. I was throttling with the waves up and down a bit to avoid hitting hard between waves. I felt the motor lose some power and I down throttled immediately and turn off the motor. Took the top off, turned the crank wheel by hand almost all the way around and it stopped short of a full rotation. The motor did not seize nor over heat. No alarms. Water pump working just fine. Did have some trouble getting it to start while at the ramp, had to throttle up a bit just to keep her from idling strange. Will say that earlier in the season, every time in reverse there was some knocking and some abnormal idling as well. There is no visual sign of anything broken, fuel injectors are not leaking, no oil spills anywhere. I started the motor once while in the water, cranked fine but knocking and was turned off immediately.
Any ideas on what may be wrong? Someone said I needed to replace the power head. Another said go get a new motor. Another said maybe a rebuild kit would do the trick.... need some help.
