Blackeyes02
When hooked up to hose at flush line pee hole drips and have heavy flow out the prop hub. Ran engine at dock for about 20 minutes at 2000rpm with no problem. System operated normally last season but pee was a little weak at idle.
Preseason did the following
New water pump (complete)
Cleaned water jacket with new gasket at VST
Removed t stat and cleaned both + housing with new gasket
What could be the problem? Pressure relief valve?
Other engine operates as it should.
Greg
Greg
