I have a 2003 ox66 225. Replaced lift pumps 06-2017. Replaced fuel filters 10-17. Problem is motor runs fine for most of the day then out of nowwhere when cranking it will run for about 1/2 sec and die. Then will turn over but not crank. Took my mechanic out in it before Christmas and it finally did it. Tested fuel pressure. Had 0. Traced wires from fuel pump to
ecm. Not getting power to fuel pump. Said was the computer. Replaced it. Took it out yesterday and still has same issue. Will crank after extended period of time. But not right away.
