hennessyktm
After much googling, forum searching, etc. decided to post. Picked up a 2003 Johnson 25 J25RSTC from an older gentlemen who said he was tired of fooling with it. It was hard to start, would run and idle rough. The guy said the fuel pump cover was cracked so he replaced it. Blamed this for the poor running admm said the carb probably just had to be cleaned. Current status: Compression is 101 and 106 psi cold, throttle wide open. Excellent spark on both cylinders. Hard to start, idles rough, and I get quite a bit of milky/oily fuel residue all over the outside of the midsection and lower unit after running it in a barrel, and, asmall puddle of the stuff on the garage floor after running it/leaving it sitting. It oozes this milky fuel/oil out of the top weep hole in the lower unit - this is not gearcase oil, it is fuel/oil/water mix...stinks like gas. The spark plugs are WAY too clean when I pull them, almost spotless except covered in gas. I assume unburnt premix is "cleaning" them rahter than detonating and leaving some soot/black/tan color. I have changed the waterpump, gearcase oil, driveshaft seals, rebuilt/cleaned the carb (new float, float needle, needle seat, gasket, set float so it is parallel with carb body when turned upside down), reset the air mixture screw to 1.5 (now 2) turns out, adjusted the throttle cam roller so it is between the 2 timing marks of the cam when the carb butterfly just starts to open, and adjusted the idle screw so it is making contact with the throttle stop and idling. I am thinking one of the following, or a combo:
- the fuel pump is somehow delievring way too much fuel
- the float is allowing fuel to bypass/get into the combusiton chamber
- the timing is WAY off
- the lower crank seal is shot. Really hoping it isn't this.
