I recently bought a very low hour 2003 BF25A, the carbs were gummed up from sitting a couple years and most likely ethanol gas issues. It would run at WOT fine but missed and stumbled at idle so I tore the carbs apart and cleaned as well as replaced the low speed jets. Cleaned the tank and got fresh non oxy gas new gaskets etc. hooked it all up and it ran perfect idled like it should and everything... then about 20 minutes later on the water it started missing at idle and acting up again on low speed. Got home and completely tore the carbs apart thinking something got sucked in from the lines or whatever and this time removed the limiters then removed the pilot screws and tossed everything into the sonic cleaner. Everything is spotless ready to go so my big question is what is the factory setting for the pilots to start from?
