dagostino82
Hi There,
I have a 2003 BF225 that has had an intermittent revving up and down at idle and when the boat just is in gear out of idle. At any RPM higher than idle and just in gear, the revving seems to go away. Well lately, The revving at idle is more pronounced as if the motor wants to stall on the low rev. The motor is also stalling a lot when throwing it into neutral. My primer bulb has been installed with the arrow pointing down since day one. I thought that might be the problem so I flipped it to where the arrow faces up for the check valve, but that did not help.
- Fuel lines from gas tank are 5/16" A-1 15 and a couple years old.
- Fuel line and primer bulb from external water separator to motor is 3/8" A-1 15 and is a couple months old.
- Primer bulb is a little squishy when the motor is revving. Not rock hard.
- High pressure and low pressure fuel filters are a month old.
I think its a fuel issue but not sure what to check. Any suggestions? Thanks!
