"I ran into a problem last tim
"I ran into a problem last time out when the engine suddenly overheated after getting up on plane. I checked the usual suspects (raw water pump, intake hose and outdrive, thermostat, etc.). Nothing jumped out at me as looking suspicious. I replaced both risers, circulation pump, thermostat, and water temp sensors. I put it back in the water this past weekend and it did the same thing. While I was flushing the engine, I felt both risers and the starboard riser was noticeably hotter than the port, The port one felt almost cool to the touch. I believe I have narrowed down my problem, but what would cause one side to run hotter than the the other? Any help you can provide would be greatly appreciated."
