Hi,
So I am completely lost at the moment. I have a 2003 Campion Allante 545i SS with 4.3GXi TBI engine that I recently picked up on trade, 95% finished. I say that, because the previous owner replaced the engine block after it froze + cracked and put it back together to the point that it runs (and well), but hadn't buttoned absolutely everything up.
Now, when I start it, it comes right to life and idles perfectly around 600-700rpm or so. It also revs up as it should in neutral, and I can confirm it will rev over 4000rpm (though I have only shot it up there briefly to see if it was restricted). So in theory it runs as it should. The issue I have, is with the warning chime beeping while it is running. When I put the key in on, it does the double beep and all is well, fires up right to life. Shortly after idling for a few seconds, the warning chime starts. It's goes: "Beep..................Beep Beep...................." and repeats. Though I have looked into it, and I have the Seloc service manual, I can't get a clear view of whether or not the system beeps out trouble codes. And in the even that it does, if that's a 12 it's beeping out, that number isn't in the manual. Now if its 21, that's a TPS issue.
So my questions start:
- Does it beep out the trouble codes once started?
- If so, what code is it referring to?
My first hunch was the sensor that is connected, but hanging freely right infront of the flame arrestor. It comes off of that main harness going over and around the front of the intake manifold and I have absolutely no clue where it goes. By running the part number through google i've discovered it's a common Intake Air Temperature sensor that is connected. ( I say common because it looks as if several manufacturers in automotive use it ) I can't for my life figure out where it screws in. The connector is 2 pin with wire colours Tan/Yellow and Grey/White, and only connects to this sensor and doesn't fit anything else. Perhaps there is a plug in place of where it's supposed to go? But then i've never heard of an IAT that plugs into an intake manifold, they're usually in the intake snorkel/plumbing. But then again I only know of automotive application. The connector is live as it has 5V running to it. Reading my Seloc manual, they make reference in wiring diagrams to the IAT, but they never actually show a location of it, AND I can't match up the wire colours. It's has a threaded brass fitting so it MUST screw into the manifold somewhere, but I can't find anywhere it would go. The pigtail that comes off of it is maybe 5 inches in length.
More questions:
- Is this an IAT sensor? Is this engine known to have an IAT sensor in marine application?
- Is there a trouble code for the IAT? I can't find one if there is.
Lastly, the Temperature gauge doesn't seem to function. I haven't looked too far into it yet, but there's 5V going to the ECT sensor on the thermostat housing (front of the engine), and when I bridge the terminals on the connector it makes no difference on the gauge, it just sits at the bottom of the gauge. Also, when I apply ground to the 5V it also makes no difference on the gauge. When I unplug it, still no difference. When I have the key off, all of the gauges fall including the Temp. When I turn the key into ON or when running, the gauges all shoot up to their resting position, including the Temp.
Does anyone have any ideas for any of these issues? I've attached a picture of my engine sans cover + flame arrestor, so you are able to see what I mean when I talk about that alleged IAT sensor.
Thanks a million in advance. I feel like such an idiot being so confused by what's probably such an simple issue.
More questions:
