2002 Yamaha 50HP 4 stroke idles smoothly but misses when run full throttle
BMG1950
Any ideas where to look for the problem? Mechanic checked carburetors and changed spark plugs but still not fixed. Charged us $600 and still not fixed. Motor idles fine but misses when we try to run it on open water.
I find another mechanic! Next I'd suspect the carb. When you run it wide open it up it may be starved for fuel. Also take it back a demand better service for your $600!
pump the bulb and see if it makes a difference....depending on its location you may need a 2nd person in the boat...if he is at the rear of the boat and behind you be careful as the speed may be varying...surging....
I had the same on my yamaha 50hp IT WAS STARVED OF FUEL WOULD EVEN STALL If I echelons rated to quick
try a carby cleaner like sea foam and run that through also replace the fuel filter and check fuel tank for contaminants
