Here is the situation that I need help on. I have a 2002 50 HP Mercury outboard that starts right up but after a few minutes of idling the hi temp alarm goes off. Water is coming out of the tell tale at what appears to be normal pressure but it's coming out scalding hot and engine block is too hot to touch. I removed the thermostat and put in boiling water and it seemed to work. One thing I noticed when I removed the thermostat was that there didn't seem to be any water residue in the opening where the thermostat goes. Is that normal? I also ran the engine with the thermostat removed expecting to see water coming out the opening but nothing came out. Should water come out that hole?
The only other thing I can think of is if the oil injection failed causing high friction and heat in the cylinders. How would I know if that failed? Any other suggestions on what I should be looking at next? Thanks in advance for any help you can provide
