Per Faztbullet:
"Get a factory manual and test ignition then rebuild carbs with new kits."
While doing that, inspect the carbs for little black specks under the top plate and in the bowl, and ensure you solvent clean the whole disassembled carb, run a wire in all holes you can find, and lots of 100 PSI air pressure to blow things out....ensuring the high speed jet...in the bottom of the bowl, is clean. If you find any black specks, install new fuel lines in the engine and if doing that, might as well install a new tank to engine line and bulb.
Replace the engine fuel filters both the large one and the small one just behind the oil tank on the aft side, midway up. Cut them open and if you see any black specks and tan chips, you are solidifying what I said above...hoses are shot and dirty. Then check your linkage plastic parts for wear and if any slop or broken pieces get new. Finally do a link and sync per the manual.
Adding Sea Foam to the fuel was a habit of mine and I was convinced it was worth the money and time, there and in other engines I have around the farm. I have been running 2002 3 and 4 cylinder engines since 2004, currently running the 115, and the above comments are some of my maintenance history. Course I have a couple more personal tweaks on the 115 but that's another story.
