2002 merc 40.oil alarm
Try this...
On your model the oil alarm "only" tells you if there is oil in the tank, not whether or not the pump is actually functioning. Because of that I find the "alarm" of very limited value - if you top up the oil before every outing you never have to worry about running out of oil. So if you have continued "false alarms" I would simply disconnect the sensor rather than replace it. The tank on these will hold enough oil for about 7 hours of run time at full throttle - likely more "hours of oil" than "hours of gas" in the tank.
