Chris Williams
This outboard has 400 hours on it, definitely had a lot of time in salt water. It had a fuel/wat serparator on it, but changed it and installed a Racor. Also all new gas in it now, but it is somewhat tough to start, I use the choke a lot and lately the only way I can get it to fire easily is with a little throttle in neutral. I don't know if this is normal or not. The engine seems smooth mostly when it is running but around 1400rpm when idling i hear the motor cough and it just keeps going, after a little revving and running its fine.
One other odd item is that the max rpm I can get with a new 3 blade prop is about 5400 rpm.
I pulled a wire off every cylinder as it was running and each one definitely made it run badly, so I am firing on all cylinders,
But I am wondering if maybe I have a slow jet clogged on one cylinder, not enough to cause big troubles, but I dont have those, just a little tough to start and the occaisonal coughing.
I would really appreciate any experienced you have with this motor.
I am wondering about pulling the carbs off and installing new jets and orings, cleanign them all up, but it looks hard on this motor.
Thanks in advance sorry for the very LONG post!
Chris
Chris
