I could use some help identifying a problem with my 2002 Johnson 40hp. (J40PLSNF).
Background: The engine is on a 16ft fiberglass center console, not underpowered for the boat but definitely at the low end of HP for it.
The boat will usually start fine, sometimes I need to rev the engine to get it running if it won't start right away.. Performs well at low speeds, but when i bring it to WOT the engine stays at around 3000rpm and will not plane or get up to top speed. No excess smoke or anything, just sounds like the engine is stuck in between gears almost. In the past, when the boat has performed properly it will do 18-20kt in glassy conditions, when it won't reach top speed at WOT it is topping out at 9kt. I only get to use the boat 5-10 times per season and this low power situation happens about 90% of the time.
Occasionally, but very rarely, when the boat is performing poorly like this after a little while at the 9kt WOT, the engine will start to rev up on its own and reach top speed, i can't seem to replicate this performance on command however!
I feel like it could be a possible fuel problem, so i have replaced fuel tank, Racor fuel filter/water separator, fuel line and connectors leading up the engine with no luck. I replaced the VRO last season and have brand new spark plugs at the beginning of this season. This week I put a fresh tank of gas mixed with 1pint SeaFoam and ran it for 30 minutes with no results. There is an inline small white plastic fuel filter inside the engine which i have not replaced but didn't know if that was necessary or not.
Not sure where to turn to now, any advice would be greatly appreciated.
Thanks!
Thanks!
