saoceallaigh
Hi,
Have had lots of reliability issues recently with difficult starting/unwillingness to start, not giving full power.
which was put down to carb dirt.
Workshop said my tank was clean and fuel clean so cleaned the (single) carb, took loads of money and said it was A1.
Next fishing trip took about forty pulls to get it started for home and it still conked again in sight of the pier.
Went back to workshop they threw out my fuel said it had been bought at a dodgy forecourt and that they only endorse one brand of gas.
They cleaned the carb found no dirt made no difference.
Then they swapped out the coil under flywheel no improvement.
they replaced one of the coilpacks and that did seem to improve the spark for that cylinder and give more power flat out.
Keeping it running at idle was still a problem. Compression was 120 on both cylinders.
With 6.00 pm on a Friday looming they again took loads of money and said it was an old engine with (in their opinion) huge hours done and I should keep upping the idle revs if the problem persisted also ordinary TCW3 oil was no good only Quicksilver or Yamahalube would do.
The engine is usable but idle is fast and there is a bit of a clunk/crunch on going into forward.
I feel there is very little wrong with it and these guys talk a lot of BS!
Any comments/advice appreciated.
