"[b]0T555997[/b]
All a s
"0T555997
All a sudden will not idle, has fuel pressure, good spark, i have not checked compression but is turns over nice and even sounding. as far as i know the engine ran fine and was put away 2 weeks later it will not idle. It will run fine if you advance the warm up lever to over about 1500rpm, or so. it runs fine there and up.
I only had a few minutes on this engine, and will be back on it Mon, or Tues.
Is there an IAC motor? TPS? MAP?
What do you think will cause something like this.
thanks."
All a s
"0T555997
thanks."
