I charged up the battery and hooked up the hose hit the key and the motor cranked and cranked. Normally on the first start of the season it cranks a few times but starts fairly quickly with the aid of the electronic fuel pump. No luck this year. I originally thought no fuel or bad gas so I went to go get a can of starting fluid(ether) and still nothing. So I starting checking plug wires and I didn't see a spark when the motor turned over. Then I pulled off the coil and found no spark there when I turned the motor over. I used my meter and found 12.5 volts at the purple side + of the coil but I wasn't getting any spark. So I replaced the coil and still no luck. Out of ideas. Any help would be appreciated. Thanks.
