I replaced the ignition switch I had problems getting the wires attached so I sprayed teflon spray on connectors and tried the switch it worked. I decided to spray the stuck remote trim switch and key hole since it was hard turning, now the key switch is dead no power to the motor. Did I blow a fuse or relay? I have a new ignition and trim switch ordered and won't spray them lesson learned. Is there a main fuse or relay I should check if the new parts don't fix the problem?
thanks
thanks
