Lone_RT_rider
I've had an issue happen while out on the lake this weekend. This is the second time this has happened. The boat is a 2001 Monterey Montura 218 LS Bowrider. It has a 5.0 EFI GM engine. This is my first post to this forum, so please be gentle.
I will try to describe the sequence of events as best I can.
I know the basics of where to start of Gas, compression and spark. Does any of this sound familiar? Any ideas would be appreciated.
Shawn
- I started out in the morning with the boat runing just fine. It started up without issue and ran perfectly.
- We ran the boat for about 20 minutes and various RPM's and speeds and ran about 5 miles up the lake (lake Hartwell, SC side).
- We stopped the boat and therefore shut off the engine for about an hour to swim and just relax.
- I restarted the engine to move the boat and the engine started fine at first (5 seconds max).
- Then the engine surged up and down at idle between 750 RPM and about 1800 RPM two or three times over about another 5 or 10 seconds.
- Then the engine shut off completely.
- I tried to restart the engine and it did come partially to life, sputtered for a bit while barely idling and then shut off. The engine only stayed running for a short time of 5 seconds or so. It did this 3 times and then would not start again after that.
- The engine would not start after that. I eventually ran the battery down trying to restart the engine. This happened to a point where it needs to be recharged.
- I ended up getting a tow back to the Marina where the boat sits in my slip awaiting my attention.
Shawn
