2000 yamaha 50 outboard
jetcraft
We were running at 28 mph when I knocking started instantly. It only has the knock when its in gear and over 8 mph. I can run it in neutral at full RPM and it has no knock. boat shop is saying they think it is a rod but in my experience with motors a rod will knock as soon as the motor runs and it is always moving and it won't knock unless its in gear. Any ideas what it could be???
Check the lower unit for metal shavings or chunks.
Does it do it in R ?
Sounds like the clutch dog might be bad??????
Take the lower unit apart and check the dog for wear.
Post some pics.
Thanks Jerry! going to get it now and will check that right away. if that's all good ill post the video I took of it when it happened.
