Not sure if this should be a new thread or a continuation. please forgive my lack of etiquette.
2001 mercury 125 2 stroke is overheating. I limped it home and replaced the impeller (the old one is 6 years old looked like new.) I replaced the thermostat. The old one looked black and crusty but opened in boiling water. I also installed a new poppet valve diaphram. On the advice of the helpful people on this website I attached a hose to the pipe above the water pump. Water flowed freely through the missing thermostat so the water jacket is not plugged.
I test ran it on muffs and the tattle tale was not running really strong but it was running.
Water was running out of the front motor mount as well. Photos attached.
I lake tested it and it ran 5 minutes before the overheat siren went off.
I noticed that the tattle tale ran continuously but water was coming from the front of the leg around the upper mounts.
I am now at home with the gear case off. I put the hose back on the water pipe and it doesn't seem to leak too bad.
I was hoping for a simple o ring or gasket failure at the top of the water pipe but it doesn't look likely.
Any body have any ideas?
Should i pull the power head?
It still seems to run like a top other than the overheating issue. I did the gear case 6 years ago and other than that it is stock original. I've had it for 12 years.
Thanks very much for your help.
Jeff Hanratty
Jeff Hanratty
