"Hi, I lost compression on the
"Hi, I lost compression on the second cylinder/ piston while in the water, 4 mlls to shore, and made it back, it kept on dying out, I would start it agian but would die if I tried to accellerate.
Previousely, the two bottom carburators had the floater's needle valve stuck against its seat and no gas reached the floater's chamber, I cleaned all three but didn't repair the carbs.
I think this incident could've caused the cylinder's failure.
The compression test, #1 135, #2 10, #3 135.
Could I just repair #2?
And how does the inner part of the motor lubricate, could the lack of gas and oil in the carburator cause the piston to fail."
