carloliveira
Show up to the dock 4:30 am pump bulb choke and start engine she stumbles once I choke and start again she runs in idle everything like usual for a 2 cycle kinda used to that start. Idle is fine warm up 20 mins pisser is good and we head out to the spot. After a 45 minute run at 3800-4200 RPM we let the engine run in idle for 5 mins prior to shut down to start some fishing, the entire time there was no stumble, no miss, no fart, no sneeze, no cough, everything as I would expect out of the outboard including no excessive smoke at idle or run. Fished a drift for about 30-45 mins and at next start up the engine idled rough stumbled, a fart and cough out of the exhaust, had to restart 3 times, had to advance the throttle a little to keep it running to prevent it dropping out. After running the engine a little bit with the poor start it will run normal again even idle correctly. Engine has 430 hours fuel is treated with startron every fill, engine fogged every fall, compression is 95-100 all cylinders, XD50 2 cycle oil since I have owned it, new separator and fuel filters this spring, also tested on a remote tank and it did the same, VRO replaced last year, new plugs and checked gap before install in spring, passes 7/16 gap spark test, fuel bulb form and replaced last season. This intermittent problem is happening more often this season but it occured less than a handful of times last season.
For others who have had this similar failure what was the solution for this intermittent problem even if you could point out what particular devices were the root cause failure I will test the device along side the instructions of my Johnson Evinrude service manual.
