Rickyj.bergeron
I have a 2000 johnson 150hp that im trying to rebuild the lower unit on. I removed the bearing carrier from the prop shaft. And water pump and seal housing from drive shaft. But i dont know how to get the prop shaft out of the housing. Do i remove the driveshaft nut under the pinion gear and remove the drive shaft first. Someone out there please lead me in the right direct
