Re: honda outboard water pump
If it has the rectifier next to the shift linkage , it is best to take that bolt out.----------Then it is easier to remove the pin.----------------Next you need to remove the 4 bolts about mid way up the exhaust housing.-----------Then you drop the lower unit and the mid exhaust housing together.-------------Measure where the piece is at the top of the shift rod is and remove it.--------Now you can remove the bolts at the lower unit to get at the pump.----------It is actually quite easy to do.------Long nose needle plier are needed.
