So I’ve got both motors working like normal. It was a bad wiring harness all along. The pdf shop manual does a very good job of troubleshooting the various sensors and mil lights. Basically check sensor and see if you have 5v. Use the sensor 5v and the engine as ground. Then check the green ground wire each sensor has. I’m generalizing.
I was able to open up the harness and locate the bad wires. Basically a bad ground at was affecting 5 sensors and a bad wire that went to my MAP sensor. Didn’t help that I mixed up the MAP sensor and another when hooking it back up.
be careful unplugging things. I was very nervous undoing the wires, but it was actually quite easy to hook everything back up. Each plug is unique, and the harness wraps around the engine like a U. BUT I discovered two plugs on the front on the intake are the same. Just a different color plastic plug. If you get them switched, engine won’t start. Be careful. The MAP sensor and the throttle position sensor are the same. The throttle position sensor is the blue one. If you get them backwards the engine is very hard to start and idles very very rough and surges.
