Hello all,
A few weeks ago, we submerged our 1999 50hp, 2 stroke Johnson in salt water while the engine was running. I'm pretty sure we were successful in our triage and got the engine cleared of water in the first few hours. Within 12 hours or so, we had the engine running at least for 20 seconds at a time. Right now, it starts fairly easily and then quits. I've pulled both carbs off and pulled them apart twice to clean them (however, I did not adjust anything in the carbs - just sprayed them out with cleaner and compressed air).
I'm getting good fuel line pressure in the bulb and the engine still dies when I pump the bulb and when I remove the cap from the fuel tank.
Where are the likely troubleshooting start points to resolve this? My gut is telling me it's still the carbs; however could it be the fuel pump? How can I best troubleshoot and rule out the fuel pump as the cause?
I have the service manual and I'm about to pull the carbs off for the third time and methodically clean them...but these are shots in the dark at the moment.
Thoughts???
Thanks for any help!
Thoughts???
