"An awful lot of boat for a li
"An awful lot of boat for a little bit of motor.
Two issues - unrelated - first off, unless the motor was serviced, like the day before you got it, you have to assume it was NOT ready for the water.
Worst thing you can do with a used rig is just launch it and fire it right up.
You have to assume, unless you have reciepts to prove otherwise, that it needs a waterpump service, new gear oil and a general tune up.
The "shaking" could be due to dirty carbs, old gas, old plugs etc.
So first off, service the engine (either yourself or have a shop do it) - you have to assume it has been sitting "unused" and "unmaintained".
Secondly, that is a big heavy boat (1520 pounds dry) with a total payload of another 1600 or so pounds - that's alot of weight (over 3000 pounds) to potentially be pushing with a 40 horse.
To make things worse, it a pontoon, so not even a planing hull to try and help out the motor - it's like trying to power a dock through the water.
It is rated for a 75 horse motor. Somebody skimped when they bought her. A knowledgeable rigger or salesman would have suggested that it be powered with a 60 Bigfoot at minimum.
The 40 may have been the cheaper alternative, but it has left the rig significantly underpowered.
If you are not in a position to replace the motor, at the very least you should get it running properly and then invest in a substantially lower pitched prop, matched to the way you will use the boat (normal payload etc).
This is never going to be a speed demon, but it should allow you to putt around the lake without overloading the motor if it's tuned and rigged correctly..."
